[postgis-users] Incorrect results from queries specifying an SRID
Paul Ramsey
pramsey at refractions.net
Thu Jun 3 09:24:51 PDT 2004
Actually, this is a slightly user-hostile annoyance I ran across last
night while writing the PostGIS workshop for MUM (I hope everyone is
coming, I expect to see all 450 of you there (and expect all of you to
buy me a beer (the workshop might be a little disjointed))).
Since box3d's cannot hold an SRID, if you ever get a cast into box3d,
you lose your SRID, which results in ugly SQL like this:
WHERE the_geom && setsrid(expand(geometryfromtext('POINT(100000
100000)',42102),100),42102)
(I recognize that I can shrink the lenght of it a bit by not initially
declaring an SRID, it will get stripped later, after all.) To the user
it is not immediately obvious why the more straightforward SQL does not
work:
WHERE the_geom && expand(geometryfromtext('POINT(100000
ERROR: Operation on two GEOMETRIES with different SRIDs
You make a geometry, and expand it, seems like a nice obvious piece of
SQL, but the error message you get says your SRIDs mismatch. But you
set an SRID, it's right there in the SQL! Confusion reigns.
On Thursday, June 3, 2004, at 01:36 AM, Mark Cave-Ayland wrote:
> Hmmm..... I can't see why this one doesn't work. All I can think of is
> that the BOX3D cast causes the SRID not be set or set incorrectly. I'll
> try and have a look at this in the near future, however I'm not sure
> exactly when I'll be able to get around to it.
Paul Ramsey
Refractions Research
Email: pramsey at refractions.net
Phone: (250) 885-0632
