[postgis-users] addgeometrycolumn() does not exist
Paul Ramsey
pramsey at refractions.net
Fri Jun 4 17:06:01 PDT 2004
Is it possible you have not enabled PostGIS by loading the postgis.sql file?
Aaron Steele wrote:
> dear readers,
> i'm running postgresql 7.4.2 with postgis 0.8.1 on linux redhat 8.
> i successfully converted a shapefile (cnty24k97.shp from
> http://gis.ca.gov/BrowseCatalog.epl) into sql (shp2pgsql cnty24k97.shp
> counties mapitdb > counties.sql). while uploading it to my database
> (psql -d mapitdb -f counties.sql), i get this error:
> <error>
> psql:counties.sql:1: ERROR: syntax error at or near "#" at character 76
> psql:counties.sql:2: ERROR: function addgeometrycolumn("unknown",
> "unknown", "unknown", integer, "unknown", integer) does not exist
> HINT: No function matches the given name and argument types. You may
> need to add explicit type casts.
> BEGIN
> psql:counties.sql:174: ERROR: syntax error at or near "#" at character 51
> psql:counties.sql:175: ERROR: syntax error at or near "#" at character 51
> COMMIT
> psql:counties.sql:176: ERROR: relation "counties" does not exist
> psql:counties.sql:177: ERROR: relation "counties_gid_seq" does not exist
> </error>
> here is a snippit from the converted shapefile:
> <snippit>
> CREATE TABLE counties (gid serial, AREA float8, PERIMETER float8,
> CNTY24K97# int4, CNTY24K97- int4, NAME varchar, NAME_CAP varchar, NUM
> int4, FIPS_CODE int4);
> select AddGeometryColumn('','counties','the_geom','-1','MULTIPOLYGON',2);
> begin;
> Insert into counties (gid,AREA,PERIMETER,CNTY24K97#,CNTY24K97-
> ,NAME,NAME_CAP,NUM,FIPS_CODE,the_geom)
> values('0','2625844992.000000','306174.219000','2','3','Del Norte','DEL
> NORTE','8','15',GeometryFromText('MULTIPOLYGON(((-346072.6875
> 440055.6875 ,-346105.3125 440068.65625 ,-346134.65625 440091.03125
> ,-346175.34375 440118.75 ,-346328.84375 440208.3125 ,-346462.90625
> 440279.8125 ,-346547.65625 440322.875 ,-346624.65625 440345.6875
> ,-346687.46875 440362.0625 ,-346797.8125 440381.90625 ,-346850.78125
> 440393 ,-346927.84375 440413.84375 ,-346956.21875 440425.6875
> ,-347058.15625 440439.78125 ,-347101.46875 440440.09375 ,-347178.28125
> 440433.4375 ,-347243.34375 440432.40625 ,-347343.28125 440426.46875
> ,-347395.28125 440426.03125 ,-347449.1875 440415.6875 ,-347486.875
> 440412.34375 ,-347517.9375 440396.8125 ,-347558.875 440385.0625
> ,-347583.40625 440385.812...
> </snippit>
> any thoughts?
> thanks,
> aaron
> postgis-users mailing list
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
