[postgis-users] addgeometrycolumn() does not exist
Aaron Steele asteele at berkeley.edu
Fri Jun 4 17:25:58 PDT 2004
hi paul,
yes, i enabled pl/pgsql with 'createlang plpgsql <mydb>'. is this what
you mean?
thanks,
aaron
On Jun 4, 2004, at 5:06 PM, Paul Ramsey wrote:
> Is it possible you have not enabled PostGIS by loading the postgis.sql
> file?
> Aaron Steele wrote:
>> dear readers,
>> i'm running postgresql 7.4.2 with postgis 0.8.1 on linux redhat 8.
>> i successfully converted a shapefile (cnty24k97.shp from
>> http://gis.ca.gov/BrowseCatalog.epl) into sql (shp2pgsql
>> cnty24k97.shp  counties mapitdb > counties.sql). while uploading it
>> to my database  (psql -d mapitdb -f counties.sql), i get this error:
>> <error>
>> psql:counties.sql:1: ERROR:  syntax error at or near "#" at character
>> 76
>> psql:counties.sql:2: ERROR:  function addgeometrycolumn("unknown",
>> "unknown", "unknown", integer, "unknown", integer) does not exist
>> HINT:  No function matches the given name and argument types. You may
>>  need to add explicit type casts.
>> BEGIN
>> psql:counties.sql:174: ERROR:  syntax error at or near "#" at
>> character  51
>> psql:counties.sql:175: ERROR:  syntax error at or near "#" at
>> character  51
>> COMMIT
>> psql:counties.sql:176: ERROR:  relation "counties" does not exist
>> psql:counties.sql:177: ERROR:  relation "counties_gid_seq" does not
>> exist
>> </error>
>> here is a snippit from the converted shapefile:
>> <snippit>
>> CREATE TABLE counties (gid serial, AREA float8, PERIMETER float8,
>> CNTY24K97# int4, CNTY24K97- int4, NAME varchar, NAME_CAP varchar, NUM
>>  int4, FIPS_CODE int4);
>> select
>> AddGeometryColumn('','counties','the_geom','-1','MULTIPOLYGON',2);
>> begin;
>> Insert into counties  (gid,AREA,PERIMETER,CNTY24K97#,CNTY24K97-
>> ,NAME,NAME_CAP,NUM,FIPS_CODE,the_geom)
>> values('0','2625844992.000000','306174.219000','2','3','Del
>> Norte','DEL
>> NORTE','8','15',GeometryFromText('MULTIPOLYGON(((-346072.6875
>> 440055.6875 ,-346105.3125 440068.65625 ,-346134.65625 440091.03125
>> ,-346175.34375 440118.75 ,-346328.84375 440208.3125 ,-346462.90625
>> 440279.8125 ,-346547.65625 440322.875 ,-346624.65625 440345.6875
>> ,-346687.46875 440362.0625 ,-346797.8125 440381.90625 ,-346850.78125
>> 440393 ,-346927.84375 440413.84375 ,-346956.21875 440425.6875
>> ,-347058.15625 440439.78125 ,-347101.46875 440440.09375
>> ,-347178.28125  440433.4375 ,-347243.34375 440432.40625
>> ,-347343.28125 440426.46875  ,-347395.28125 440426.03125
>> ,-347449.1875 440415.6875 ,-347486.875  440412.34375 ,-347517.9375
>> 440396.8125 ,-347558.875 440385.0625  ,-347583.40625 440385.812...
>> </snippit>
>> any thoughts?
>> thanks,
>> aaron
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>       __
>      | Paul Ramsey
>      | Refractions Research
>      | Email: pramsey at refractions.net
>      | Phone: (250) 885-0632
>      \_
Name: not available
Type: text/enriched
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20040604/5593b684/attachment.bin>
