[postgis-users] general postgreSQL
Markus Schaber
schabios at logi-track.com
Tue Jun 8 01:53:02 PDT 2004
Hi, Eric,
On Mon, 07 Jun 2004 17:38:18 -0400
Eric.Hillmuth at anr.state.vt.us wrote:
> For lack of a better option I upgraded to postgresql 7.4.2 and postGIS
> 0.8.2. but this didn't seem to help. I still get:
> LOG: could not bind IPv4 socket: Address already in use
> HINT: is another postmaster already running on port 5432. If not, wait
> a few seconds and retry.
> 5432 opens when the postmaster starts up and closes when the
> postmaster shuts down. I'm using "postmaster -D data -i" for startup
> and "pg_ctl stop -D data -m fast" for shutdown. Things should be as
> clean as can be so I'm not sure what its complaining about. I'd be
> interested to know if anybody on the list is running SUSE 8.4?
Issue the following command as root:
netstat --listening -n --tcp --program | grep 5432
You should get a line like
tcp 0 0 0.0.0.0:5432 0.0.0.0:* LISTEN 923/postmaster
This tells you which program and pid has the socket open (here it is
postmaster with pid 923).
Then try:
ps auxf | grep 923
which should print something like:
postgres 923 0.0 1.0 35888 10876 ? Ss 09:05 0:00 /usr/lib/postgresql/bin/postmaster -i -p 5432 -D /crypt/postgres
So you know where your postmaster process came from, where its binary is.
Is this the location you installed your postmaster?
HTH,
Markus
markus schaber | dipl. informatiker
logi-track ag | rennweg 14-16 | ch 8001 zürich
phone +41-43-888 62 52 | fax +41-43-888 62 53
mailto:schabios at logi-track.com | www.logi-track.com
