[postgis-users] general postgreSQL
Eric.Hillmuth at anr.state.vt.us Eric.Hillmuth at anr.state.vt.us
Tue Jun 8 06:08:09 PDT 2004
Thanks for the feedback Markus;
I did what you suggested and there is just the one postmaster running
where I installed it so nothing unexpected.
Interestingly I found a discussion
(http://www.dbforums.com/archive/index.php/t-968701.html ) that seems
to indicate the message is related to IPv6 conflict and can be ignored.
On 8 Jun 2004 at 10:53, Markus Schaber wrote:
> Hi, Eric,
> On Mon, 07 Jun 2004 17:38:18 -0400
> Eric.Hillmuth at anr.state.vt.us wrote:
> > For lack of a better option I upgraded to postgresql 7.4.2 and postGIS
> > 0.8.2. but this didn't seem to help. I still get:
> > LOG: could not bind IPv4 socket: Address already in use
> > HINT: is another postmaster already running on port 5432. If not, wait
> > a few seconds and retry.
> > 5432 opens when the postmaster starts up and closes when the
> > postmaster shuts down. I'm using "postmaster -D data -i" for startup
> > and "pg_ctl stop -D data -m fast" for shutdown. Things should be as
> > clean as can be so I'm not sure what its complaining about. I'd be
> > interested to know if anybody on the list is running SUSE 8.4?
> Issue the following command as root:
> netstat --listening -n --tcp --program | grep 5432
> You should get a line like
> tcp 0  0  0.0.0.0:5432  0.0.0.0:*  LISTEN  923/postmaster
> This tells you which program and pid has the socket open (here it is
> postmaster with pid 923).
> Then try:
> ps auxf | grep 923
> which should print something like:
> postgres   923  0.0  1.0 35888 10876 ?       Ss   09:05   0:00
/usr/lib/postgresql/bin/postmaster -i -p 5432 -D /crypt/postgres
> So you know where your postmaster process came from, where its
binary is.
> Is this the location you installed your postmaster?
> HTH,
> Markus
> markus schaber | dipl. informatiker
> logi-track ag | rennweg 14-16 | ch 8001 zürich
> phone +41-43-888 62 52 | fax +41-43-888 62 53
> mailto:schabios at logi-track.com | www.logi-track.com
> postgis-users mailing list
Eric Hillmuth
GIS Systems Developer
Vermont Agency of Natural Resources
eric.hillmuth at anr.state.vt.us
802-241-3616
