[postgis-users] Optimizer guess makes query 1000x slower?
strk
strk at keybit.net
Tue Jun 15 03:21:57 PDT 2004
What postgresql version are you using ?
Postgis built against PostgreSQL <= 74 require you to run
update_geometry_stats() to build statistics used by the
selectivity estimator.
--strk;
On Tue, Jun 15, 2004 at 03:09:23AM -0700, rm_postgis at cheapcomplexdevices.com wrote:
> Short summary:
> I have a query that is trying to find points that are
> (inside Sacramento) and
> (contained in a list of interesting points).
> Poor optimizer guess makes query take 202079 ms instead of
> 281 ms if I disable nested loops. It seems to think the
> geom index is much more selective than it turns out to be
> in practice.
> I'm using mapserver to run the query so I don't have total flexability
> in the SQL (i.e. I don't know how to "enable_nestloop=false" in mapserver).
> Any suggestions appreciated!
> Longer:
> I have 2 tables. One has all the points, along with their geometries.
> The other table has simply "pointID | user" pairs that contains
> lists of points that specific users find interesting.
> The query I'm using looks like this:
> SELECT *
> FROM cpal_events, -- points with gemoetry
> cpal_selected_events -- points of interest
> WHERE cpal_events.nextval=cpal_selected_events.eventid -- join
> and cpal_selected_events.owner='user.23469878.20252' -- for a user
> and the_geom && -- in the area
> setSRID( 'BOX3D(-121.5868 38.4277,-121.3361 38.6954)'::BOX3D,find_srid('','cpal_events','the_geom'));
> If I read the "explain analyze" result below, the optimizer
> estimates that only 1 row is returned in the geometry, so it
> does a "Nested Loop" to join with the list of "interesting" events.
> Unfortunatelly the geometry index actually returns 9570 results, so
> the query takes hundreds of times longer than it should have. By
> disabling nested loops, the query takes 281 ms instead of 202079 ms!
> (explain analyze output below). I do "vacuum analyze" regularly.
> Is there:
> a) any way I can hint that the GIST index isn't as selective as it thinks it is?
> b) any way I can tell mapserver to avoid Nested Loops
> c) something even more obvious I'm missing?
> d) any more info I could give that would be interesting to the list?
> Thanks,
> Ron
> ronmap=# set enable_nestloop = true;
> SET
> ronmap=# explain analyze
> SELECT *
> FROM cpal_events,cpal_selected_events
> and the_geom && setSRID( 'BOX3D(-121.586865184167 38.4277618656666,-121.336132412548 38.6954249341005)'::BOX3D,find_srid('','cpal_events','the_geom'));
> QUERY PLAN
> Nested Loop (cost=0.00..218.01 rows=1 width=546) (actual time=2555.501..202056.918 rows=6357 loops=1)
> Join Filter: ("outer".nextval = "inner".eventid)
> -> Index Scan using cpal_event_summary__gist on cpal_events (cost=0.00..6.01 rows=1 width=503) (actual time=0.100..261.886 rows=9570 loops=1)
> Index Cond: (the_geom && 'SRID=-1;BOX3D(-121.586865184167 38.4277618656666 0,-121.336132412548 38.6954249341005 0)'::geometry)
> -> Seq Scan on cpal_selected_events (cost=0.00..132.50 rows=6360 width=43) (actual time=0.005..12.020 rows=6357 loops=9570)
> Filter: ("owner" = 'user.23469878.20252'::text)
> Total runtime: 202079.387 ms
> (7 rows)
> ronmap=# set enable_nestloop = false;
> SET
> SELECT *
> QUERY PLAN
> Merge Join (cost=540.31..572.13 rows=1 width=546) (actual time=161.258..266.926 rows=6357 loops=1)
> Merge Cond: ("outer".nextval = "inner".eventid)
> -> Sort (cost=6.02..6.03 rows=1 width=503) (actual time=129.153..137.399 rows=9570 loops=1)
> Sort Key: cpal_events.nextval
> -> Index Scan using cpal_event_summary__gist on cpal_events (cost=0.00..6.01 rows=1 width=503) (actual time=0.103..78.088 rows=9570 loops=1)
> -> Sort (cost=534.29..550.19 rows=6360 width=43) (actual time=32.047..37.490 rows=6357 loops=1)
> Sort Key: cpal_selected_events.eventid
> -> Seq Scan on cpal_selected_events (cost=0.00..132.50 rows=6360 width=43) (actual time=0.074..15.649 rows=6357 loops=1)
> Total runtime: 281.134 ms
> (11 rows)
> ronmap=#
> postgis-users mailing list
