[postgis-users] Optimizer guess makes query 1000x slower?
    rm_postgis at cheapcomplexdevices.com
    Tue Jun 15 03:09:23 PDT 2004
Short summary:
  I have a query that is trying to find points that are
    (inside Sacramento) and
    (contained in a list of interesting points).
  Poor optimizer guess makes query take 202079 ms instead of
  281 ms if I disable nested loops.  It seems to think the
  geom index is much more selective than it turns out to be
  in practice.
  I'm using mapserver to run the query so I don't have total flexability
  in the SQL (i.e. I don't know how to "enable_nestloop=false" in mapserver).
  Any suggestions appreciated!
Longer:
  I have 2 tables.  One has all the points, along with their geometries.
  The other table has simply "pointID | user" pairs that contains
  lists of points that specific users find interesting.
  The query I'm using looks like this:
 SELECT *
   FROM cpal_events,            -- points with gemoetry
        cpal_selected_events    -- points of interest
  WHERE cpal_events.nextval=cpal_selected_events.eventid  -- join
    and cpal_selected_events.owner='user.23469878.20252'  -- for a user
    and the_geom &&                                       -- in the area
        setSRID( 'BOX3D(-121.5868 38.4277,-121.3361 38.6954)'::BOX3D,find_srid('','cpal_events','the_geom'));
  If I read the "explain analyze" result below, the optimizer
  estimates that only 1 row is returned in the geometry, so it
  does a "Nested Loop" to join with the list of "interesting" events.
  Unfortunatelly the geometry index actually returns 9570 results, so
  the query takes hundreds of times longer than it should have.  By
  disabling nested loops, the query takes 281 ms instead of 202079 ms!
  (explain analyze output below).   I do "vacuum analyze" regularly.
Is there:
 a) any way I can hint that the GIST index isn't as selective as it thinks it is?
 b) any way I can tell mapserver to avoid Nested Loops
 c) something even more obvious I'm missing?
 d) any more info I could give that would be interesting to the list?
   Thanks,
   Ron
ronmap=# set enable_nestloop = true;
SET
ronmap=# explain analyze
  SELECT *
    FROM cpal_events,cpal_selected_events
     and the_geom && setSRID( 'BOX3D(-121.586865184167 38.4277618656666,-121.336132412548 38.6954249341005)'::BOX3D,find_srid('','cpal_events','the_geom'));
        QUERY PLAN
 Nested Loop  (cost=0.00..218.01 rows=1 width=546) (actual time=2555.501..202056.918 rows=6357 loops=1)
   Join Filter: ("outer".nextval = "inner".eventid)
   ->  Index Scan using cpal_event_summary__gist on cpal_events  (cost=0.00..6.01 rows=1 width=503) (actual time=0.100..261.886 rows=9570 loops=1)
         Index Cond: (the_geom && 'SRID=-1;BOX3D(-121.586865184167 38.4277618656666 0,-121.336132412548 38.6954249341005 0)'::geometry)
   ->  Seq Scan on cpal_selected_events  (cost=0.00..132.50 rows=6360 width=43) (actual time=0.005..12.020 rows=6357 loops=9570)
         Filter: ("owner" = 'user.23469878.20252'::text)
 Total runtime: 202079.387 ms
(7 rows)
ronmap=# set enable_nestloop = false;
SET
  SELECT *
        QUERY PLAN
 Merge Join  (cost=540.31..572.13 rows=1 width=546) (actual time=161.258..266.926 rows=6357 loops=1)
   Merge Cond: ("outer".nextval = "inner".eventid)
   ->  Sort  (cost=6.02..6.03 rows=1 width=503) (actual time=129.153..137.399 rows=9570 loops=1)
         Sort Key: cpal_events.nextval
         ->  Index Scan using cpal_event_summary__gist on cpal_events  (cost=0.00..6.01 rows=1 width=503) (actual time=0.103..78.088 rows=9570 loops=1)
   ->  Sort  (cost=534.29..550.19 rows=6360 width=43) (actual time=32.047..37.490 rows=6357 loops=1)
         Sort Key: cpal_selected_events.eventid
         ->  Seq Scan on cpal_selected_events  (cost=0.00..132.50 rows=6360 width=43) (actual time=0.074..15.649 rows=6357 loops=1)
 Total runtime: 281.134 ms
(11 rows)
ronmap=#
