[postgis-users] referencing GEOMETRY object values in libpq?
    David Blasby
    dblasby at refractions.net
    Mon Jun 14 12:40:57 PDT 2004
Paul Ramsey wrote:
> Yes, a better way would be to read the "Well Known Binary", much easier
> to transform than the text form. You can get the binary forms by
> declaring a binary cursor and pulling the data that way. There is some
> example code for this in the examples/wkb_reader directory.
Its *way* easier to use the normal SQL queries.  You'll get back
something like this:
test2=# select asbinary('POINT(123 456)'::geometry);
                   asbinary
  01010000000000000000C05E400000000000807C40
You'll need to write a little function that takes a string like 'E4' and
  returns a char with the value 228 in it (this is really easy).  You'll
use this to convert the above string of 42 bytes to an array of chars
(length 21) - thats your WKB.
To go from WKB back to postgis, you just write a function that take a
number like 228 and converts it to a little 'E4' string (also really
easy).  Use GeometryFromWKB() in the database.
The down side of this is three fold:
1. You're transferring twice the data - for the above example, 42
characters (when you only really need to send 21).
2. There's a little bit of extra processing required (the conversion)
3. During the conversion process, you'll have the text version and
binary version in memory at the same time.  For VERY VERY VERY large
geometries, this might be a problem.
The advantage is that its really really simple to do.  If you actually
use BINARY cursors, you'll have to deal with a much much more complex
application because your ENTIRE query will be coming back in binary (not
just the geometry).  This is a very big pain the butt!  Trust me, you
dont want to go there.
So, unless you're really looking for performance with large geometries,
you'll find the "naive" way much easier.  The nice part is you can write
your application the "naive" way, then easily convert it to the hard way
if you find its too slow.
WKB is defined in the OGC SF SQL spec, and is easy to machine parse.
dave
