[postgis-users] referencing GEOMETRY object values in libpq?
Paul Ramsey
pramsey at refractions.net
Mon Jun 14 12:14:21 PDT 2004
Yes, a better way would be to read the "Well Known Binary", much easier
to transform than the text form. You can get the binary forms by
declaring a binary cursor and pulling the data that way. There is some
example code for this in the examples/wkb_reader directory.
Paul
sandr002 at bama.ua.edu wrote:
> I'm working on a project that requires using C, and I'm still pretty new
> to PostGIS. I'm trying to retrieve the values of the points on a
> polygon from a PGresult, using the libpq library. Is there a better way
> to do this than parsing the 'GeometryAsText()' string? I guess what I
> would like to know is if there is a way to reference
> POLYGON3D->pts->POINT3D->x/y/z to store it in a local variable of my own.
> Thanks guys,
> -Nick
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
