[postgis-users] Optimizer guess makes query 1000x slower?
strk
strk at keybit.net
Wed Jun 16 06:15:38 PDT 2004
On Tue, Jun 15, 2004 at 09:13:34AM -0700, rm_postgis at cheapcomplexdevices.com wrote:
> On Tue, 15 Jun 2004, strk wrote:
> > update_geometry_stats() needs always be run manually.
> > automatic statistics gathering for custom operators is available
> > from postgresql 75 only.
> Thanks!
> Wonder if it'd be good to add this note to the postgis docs
> page that talks about indexes:
> http://postgis.refractions.net/docs/x511.html
> I kinda would have expected to see that information there.
I've added documentation about update_geometry_stats()
and VACUUM ANALYZE.
--strk;
> > A curiosity, how many geometry records are there ?
> This table has 59000 geometry records, all in 12 cities. The
> table I was joining it with had about 10000 records.
> ronmap=# select count(*) from cpal_events;
> count
> 58890
> (1 row)
> ronmap=# select count(*) from geometry_columns;
> count
> 27
> (1 row)
> Thanks again for your help!
> The database is working very well right now!
> Ron
