[postgis-users] Postgres User Problem(newbie)
Pericles S. Nacionales
nacional at cbs.umn.edu
Mon Jun 21 08:20:38 PDT 2004
It sounds like "pg" doesn't have permission to do much of anything. If
you are using psql, try running this statement as db-admin (replace
<tablename> with your table names):
GRANT SELECT ON TABLE <tablename> TO pg;
This will allow "pg" to read your tables. If you're using pgadmin3, the
mouse is your friend.
To can learn more about PostgreSQL users and privileges, go to
http://www.postgresql.org/docs/7.4/interactive/user-manag.html
Cheers!
Perry N.
On Mon, 2004-06-21 at 07:05, Daniel Draws wrote:
> Hi all!
> I've tried the installation instructions from the postgis site
> (http://postgis.refractions.net/documentation.php), beginning with
> rpm(or emerge) and then the createlang...
> I have a problem with the following scenario (Linux: Fedora Core 1,
> Gentoo). I have 2 users on my postgresql installation. The postgres user
> is the db-admin. And I have another user (pg). PG has created a new
> database called gistest. But he can not execute the postgis scripts for
> installing the postgis functions, tables ,...
> If the postgres user executes the scripts in pg's database, pg can't
> use the created functions, tables,...
> Is there any solution for this problem?
> thx
> daniel
> postgis-users mailing list
Pericles S. Nacionales <nacional at cbs.umn.edu>
University of Minnesota
