[postgis-users] could not find function "centroid" in file "/usr/lib/postgresql/postgis.dll"
Chapman, Martin
MChapman at sanz.com
Sat Jun 26 14:45:12 PDT 2004
Rudolf,
This is a wild guess, but a centroid sounds like it could be a class/struct in the geos library. And since PostGIS uses geos for it's geometric calculations it probably needs geos installed. http://geos.refractions.net/
Martin
-----Original Message-----
From: Rudolf Nottrott [mailto:rnott at alexandria.UCSB.edu]
Sent: Sat 6/26/2004 8:57 AM
To: PostGIS Users Discussion
Cc:
Subject: [postgis-users] could not find function "centroid" in file "/usr/lib/postgresql/postgis.dll"
I installed PostGIS with PostgreSQL on Windows XP / Cygwin, after switching
off proj4 and geos in the Makefile (USE_PROJ=0 and
USE_GEOS=0). I switched off proj4 and geos because I was getting PostGIS
compilition errors without them installed, and I felt a bit daunted
about two more installs.
WIth
USE_PROJ=0 and USE_GEOS=0
PostGIS compiles and installes ok -- I just wanted to get the basic
PostGIS going first.
Unfortunatley, now when loading the postgis.sql definitions file
psql -d drg_usgs -f postgis.sql
I get an error
Any idea what that means, and what to do?
Thanks,
Rudolf
P.S. I thought that perhaps it relates to the uninstalled geos, so I
downloaded and unpacked geos, but then found no installation instructions
for it (only an empty README file).
>Subject: RE: Using/Compiling PostGIS on WindowsXP/Cygwin for use with
>PostgreSQL
>Date: Fri, 25 Jun 2004 17:45:25 -0600
>From: "Chapman, Martin" <MChapman at sanz.com>
>To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
>That is correct, fortunately the builds for these projects are really
>good and work on both linux and windows. Just download them and follow
>the build instructions. It's easier than you might think.
>Martin
>Sent: Friday, June 25, 2004 5:25 PM
>Subject: RE: [postgis-users] Using/Compiling PostGIS on WindowsXP/Cygwin
>for use with PostgreSQL
>Are you saying that proj4 and geos are required to run
>PostGIS with PostgreSQL on Windows/Cygwin?
>Are they also required to run PostGIS with PostgreSQL on other
>platforms, in particular Linux?
>If so, that adds up to quite an installation chore, mostly because of
>the potential errors that can occur.
>I feel a bit daunted!
>Rudolf
>At 05:01 PM 6/25/2004 -0600, you wrote:
> >You need to download and install proj4. It's the projection library
> >used by postgis to handle projecting lat/lons into x,y and the inverse.
> >The zip can be found at http://www.remotesensing.org:16080/proj/ .
> >Follow the build instructions for windows using the vc compiler. Let
> >me know if you have problems. You also need geos which can be found at
> >http://geos.refractions.net .
> >Martin Chapman
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
