[postgis-users] could not find function "centroid" in file "/usr/lib/postgresql/postgis.dll"
Rudolf Nottrott
rnott at alexandria.UCSB.edu
Sat Jun 26 16:37:08 PDT 2004
Thanks, Martin,
I'm attempting the geos compile under Cygwin. There is no Makefile, and
the installation instructions
(http://www.alexandria.ucsb.edu/~rnott/tmp/geos-1.0/INSTALL)
are really very minimal. Is that all there is?
The expanded geos-1.0 tree that I got from http://geos.refractions.net/ is at
for reference.
To begin with, I can't just 'make' Geos in the regular way as there is no
Makefile, only
Makefile.am and Makefile.am.
For the rest, I did the steps below, and they went fine (so all that's
missing is Geos)
My PostgreSQL contrib directory is
/cygdrive/c/cygwin/usr/src/postgresql-7.4.3-1/contrib/
I have PostGIS in
/cygdrive/c/cygwin/usr/src/postgresql-7.4.3-1/contrib/postgis-0.8.1
and Geos in
/cygdrive/c/cygwin/usr/src/postgresql-7.4.3-1/contrib/geos-1.0
Following instructions elsewhere I ran a make (but NOT 'make install') on
PostgreSQL in directory
This make went fine.
I also ran a make AND a 'make install' in
This went fine, too.
Rudolf
At 03:45 PM 6/26/2004 -0600, you wrote:
>Rudolf,
>This is a wild guess, but a centroid sounds like it could be a
>class/struct in the geos library. And since PostGIS uses geos for it's
>geometric calculations it probably needs geos
>installed. http://geos.refractions.net/
>Martin
> >Subject: RE: Using/Compiling PostGIS on WindowsXP/Cygwin for use
> with PostgreSQL
> >Date: Fri, 25 Jun 2004 17:45:25 -0600
> >From: "Chapman, Martin" <MChapman at sanz.com>
> >To: "PostGIS Users Discussion"
> <postgis-users at postgis.refractions.net>
> >That is correct, fortunately the builds for these projects are
> really
> >good and work on both linux and windows. Just download them and
> follow
> >the build instructions. It's easier than you might think.
> >Martin
>-----Original Message-----
>From: Rudolf Nottrott [mailto:rnott at alexandria.UCSB.edu]
>Sent: Sat 6/26/2004 8:57 AM
>To: PostGIS Users Discussion
>Subject: [postgis-users] could not find function "centroid" in file
> I installed PostGIS with PostgreSQL on Windows XP / Cygwin, after
> switching
> off proj4 and geos in the Makefile (USE_PROJ=0 and
> USE_GEOS=0). I switched off proj4 and geos because I was getting
> PostGIS
> compilition errors without them installed, and I felt a bit daunted
> about two more installs.
> WIth
> USE_PROJ=0 and USE_GEOS=0
> PostGIS compiles and installes ok -- I just wanted to get the basic
> PostGIS going first.
> Unfortunatley, now when loading the postgis.sql definitions file
> psql -d drg_usgs -f postgis.sql
> I get an error
> Any idea what that means, and what to do?
> Thanks,
> Rudolf
> P.S. I thought that perhaps it relates to the uninstalled geos, so I
> downloaded and unpacked geos, but then found no installation
> instructions
> for it (only an empty README file).
