[postgis-users] Schema support in loader/dumper
David Blasby
dblasby at refractions.net
Fri Mar 19 13:04:35 PST 2004
strk wrote:
>>This sounds like a lot of work. Perhaps we should just change all the
>>"CREATE FUNCTION ..." clauses to "CREATE OR REPLACE FUNCTION...". This
>>should work well for everything but the GiST support stuff...
>>dave
> That would not always work.
> For example, if you need to change the return type:
> ERROR: ProcedureCreate: cannot change return type of existing function.
> Use DROP FUNCTION first.
> What was wrong with postgis_undef.sql again ?
> Functions oid mismatch or just an ordering issue ?
> BTW: did people try using postgis_new.sql ? further changes
> in sql files would be easier if we can support CPP generation.
I dont think doing a postgis_undef.sql is such a good idea - I believe
it removes the actual postgis geometry type which will mean all your
geometry data will be un-accessible (because the type OID will not
reference anything).
I havent looked at postgis_new.sql.
dave
