[postgis-users] postgis jump driver causing wierd error
Seamus Thomas Carroll
carrolls at cpsc.ucalgary.ca
Wed Mar 17 12:11:47 PST 2004
I have added a plugin to jump that uses the postgis jumpdriver. I use the
standard postgis driver to get information from the database and then use
the jumpdriver to display the retrieved layer information. If I is use
this
code to get a connection the jumpdriver works correctly:
Connection conn = DriverManager.getConnection(url, username, password);
Yesterday I tried adding pooling to make it easier to get connections to
the database ( i need many connections ) using the following code:
Jdbc3PoolingDataSource dbPool = new Jdbc3PoolingDataSource()
dbPool.setDataSourceName( dataSourceName );
dbPool.setServerName(serverName);
dbPool.setDatabaseName(databaseName);
dbPool.setPortNumber( portNumber );
dbPool.setUser(user);
dbPool.setPassword(password);
dbPool.setMaxConnections(maxConnections);
Connection con = dbPool.getConnection();
This works out great and I use the connection as normal. The problem
occurs when I the try to use the jumpdriver to load in a layer. I now
recieve the following error:
java.sql.SQLException: No suitable driver
at java.sql.DriverManager.getConnection(DriverManager.java:532)
at java.sql.DriverManager.getConnection(DriverManager.java:171)
at net.refractions.postgis.PostGISConnection.connect(PostGISConnection.java:448)
at net.refractions.postgis.PostGISConnection.executeQuery(PostGISConnection.java:77)
at net.refractions.postgis.PostGISConnection.executeQuery(PostGISConnection.java:471)
at uavui.agentsmanager.AgentEntry.updateMap(AgentEntry.java:329)
at uavui.agentsmanager.AgentEntry.access$800(AgentEntry.java:51)
at uavui.agentsmanager.AgentEntry$AgentUpdateThread.startUpdate(AgentEntry.java:596)
at uavui.agentsmanager.AgentEntry$AgentUpdateThread.run(AgentEntry.java:583)
java.lang.IllegalStateException: Could not connection to database: No suitable driver
at net.refractions.postgis.PostGISConnection.connect(PostGISConnection.java:457)
I have no idea why adding connection pooling to my code would effect the
jumpdriver. Does anyone know of any technical issues about adding
Jdbc3PoolingDataSource to my plugin that would cause it to effect the
jumpdriver?
Thanks for any suggestions or comments,
Seamus
