[postgis-users] Yet another installation problem - and PostGIS translator
Ryan Proulx
Ryan.Proulx at safe.com
Wed Mar 24 09:14:14 PST 2004
Chris,
Thanks for the tip. At this point I have already solved the issue at hand and everything is working fine once I started from scratch again and aquired more disk space in the typical location (/usr/local/pgsql).
As for a translator for PostGIS, Safe Software has already added PostgreSQL/PostGIS to the list of 100+ formats that can be read and written by its FME product. The PostGIS Reader/Writer in particular is about a year old though it has been recently updated to support schemas and some non-PostGIS concepts like writer mode and enhances metadata retrieval.
If interested: http://www.safe.com/products/fme/formats/index.php
If only I could get answers to the WKB geometry questions I have posted I could surely write a faster PostGIS writer than at present using WKT. Then again I guess you have to balance the performance of the PostgreSQL COPY command and inserting WKT versus individual insert statements of WKB geometries. I think we would end up leaving users the choice.
Regards,
ryan
-----Original Message-----
Sent: March 23, 2004 23:35
To: 'PostGIS Users Discussion'
Subject: RE: [postgis-users] Yet another installation problem
Hello
I know that this isn't the real solution and there should be a proper
answer - but if the use of /home/postgres/pgsql is due to disk space
requirements, why not use a symbolic link ?
Couldn't help but see your email address - does this mean we can expect
a Postgres translator in FME some time ?!! This would be big news for
postgis.
Chris
