[postgis-users] Which SRID to choose?
Gerry Creager N5JXS gerry.creager at tamu.edu
Mon Mar 29 06:47:39 PST 2004
If you've questions regarding GPS, WGS-84 or the associated geodesy, I
can probably answer them for you...
Regards,
Gerry
Markus Schaber wrote:
> Hi, Homme,
> On Thu, 25 Mar 2004 10:09:47 +0000
> Homme Zwaagstra <hrz at geodata.soton.ac.uk> wrote:
>>>We currently get our geometry data in longitude/latitude format in
>>>degrees (e. G., 'POINT(8.53951 47.37704)' is Z?rich).
>>Have you had a look at the spatial_ref_sys table?  This is created if
>>you load the spatial_ref_sys.sql file when you enable PostGIS on your
>>database. I find this to be a valuable source of projection and SRID
>>information, especially as it lists the proj4 options for each SRID.
> Yes, we had, but we were rather confused by the pure amount of reference
> systems without any further pointers to explanation.
>>>Our two data sources currently are GPS receivers and Shapefiles from
>>>ArcView Premium.
>>Your GPS receivers are likely to return coordinates in the WGS 1984
>>system. The EPSG (http://www.epsg.org/) code for this is 4326.
> Thanks, I now found out that GPS really seems to use the WGS 1984
> coordinate sstem.
> Thanks for your additional Pointers to information, this seems very
> helpful.
> Greets,
> Markus
Gerry Creager -- gerry.creager at tamu.edu
Network Engineering -- AATLT, Texas A&M University
Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.847.8578
Page: 979.228.0173
Office: 903A Eller Bldg, TAMU, College Station, TX 77843
