[postgis-users] Cygwin PostGIS Installer Problem
"Morin, Marc-André"
Marc-Andre.Morin at drdc-rddc.gc.ca
Mon May 17 05:02:55 PDT 2004
Hi folks,
I got that problem only during the installation of postgis and dcmms
database on Windows Server 2000 and Windows Server 2003, where I had
previously installed Cygwin PostgreSQL version 7.4.1.
All works fine when I install the stuff on Windows 2000 Pro and Windows
XP...
So, the problem would be related to Windows Server...
If anybody has an idea how to fix it, let me know!
Thanks in advance for your help,
Marc-Andre
> -----Original Message-----
> From: Steffen Macke [mailto:sdteffen at web.de]
> Sent: Saturday, May 15, 2004 5:54 AM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] Cygwin PostGIS Installer Problem
> Hello All,
> Marc-Andre Morin reported a problem with the Cygwin PostGIS
> installer 0.8.0 and the latest Cygwin PostgreSQL version (7.4.1).
> Currently, I don't have a Windows machine around to reproduce the
> problem (or create an updated version of the installer).
> If you are experiencing the problem, you should find similar
> lines like
> psql:/usr/share/postgresql/contrib/postgis.sql:41: ERROR:
> Load of file
> /usr/lib /postgresql/postgis.dll failed: dlopen: Win32 error 127
> in c:\cygwin\tmp\create_dcmms.log
> As a workaround, you can try to use Cygwin PostgreSQL 7.4 with
> the 0.8.0 Cygwin PostGIS installer (If you still have a copy around).
> If you have encountered similar problems, please share them
> with the mailing list.
> Steffen
> postgis-users mailing list
