[postgis-users] Building with mingw32, configure for PostgreSQL
Romi Hardiyanto
rodin at ewesewes.net
Mon May 17 17:02:25 PDT 2004
My solution is to add include directory to postgis Makefile like:
override CFLAGS += -g -fexceptions
override CFLAGS += -I$(srcdir) -DFRONTEND -DSYSCONFDIR='"$(sysconfdir)"'
-I/mingw/include
override CFLAGS += -DUSE_VERSION=$(USE_VERSION)
The MinGW header files is not on search path (/include in MSys).
Romi H
Craig Miller wrote:
> I was able to get everything to compile except PostGIS with GEOS support.
> PostGIS w/o GEOS support works, and the GEOS compile works good too. I saw
> in your notes that you said you had to copy the GEOS header files to
> /include. This directory does not exist in a default msys installation.
> Did you add it?
> Thanks,
> --Craig
> -----Original Message-----
> From: David TECHER [mailto:davidtecher at yahoo.fr]
> Sent: Monday, May 17, 2004 5:36 AM
> To: PostGIS Users Discussion
> Subject: RE: [postgis-users] Building with mingw32, configure for
> PostgreSQL
> Hi Craig
> can you give me the file or the URL where you have
> seen this?
> Did you succeed in compiling?
>>I remember that you posted a message about having
>>trouble creating indexes
>>on large datasets with the mingw version of postgis
>>you compiled. I read a
>>note in the postgresql compile notes that said to be
>>sure to run postgres
>>from a normal DOS cmd prompt and not an rxvt shell
>>due to some sort of
>>memory limitation. Perhaps this is what is causing
>>the trouble with large
>>datasets?
>>--Craig
>>Sent: Thursday, May 13, 2004 8:30 AM
>>Subject: Re: [postgis-users] Building with mingw32,
>>configure for
>>PostgreSQL
>> Dear Romi
>>thanks thanks very much I succeed I succeed after
>>two
>>weeks of work
>>I'm happy...You know I'm happy :)
>>Yahoo! Mail : votre e-mail personnel et gratuit qui
>>vous suit partout !
>>Créez votre Yahoo! Mail sur
>>http://fr.benefits.yahoo.com/
>>Dialoguez en direct avec vos amis grâce à Yahoo!
>>Messenger !Téléchargez
>>Yahoo! Messenger sur http://fr.messenger.yahoo.com
>>_______________________________________________
>>postgis-users mailing list
>>postgis-users at postgis.refractions.net
> Yahoo! Mail : votre e-mail personnel et gratuit qui vous suit partout !
> Créez votre Yahoo! Mail sur http://fr.benefits.yahoo.com/
> Dialoguez en direct avec vos amis grâce à Yahoo! Messenger !Téléchargez
