[postgis-users] Re: postgis and mapserver problem
David Blasby dblasby at refractions.net
Fri May 21 09:17:40 PDT 2004
Gino Lucrezi wrote:
>>>Thanks for the help Jan. I found out what the problem was. It seems in the
>>>DATA statement of the map file the "FROM" keyword needs to be in lower case.
>>>i.e. "shape from table" not "shape FROM table"
>>>A bug has been raised for this on the map server site.
> It is:
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=623
> I raised it :-)
> Unfortunately, mapserver's bugzilla doesn't allow voting on issues, otherwise I'd recommend that Postgis users vote for it.
>>This shouldnt be the case unless you're using a mappostgis.c thats more
>>than a years old.
> -rw-r--r-- 45701 14 ott  2003 /usr/local/src/mapserver-4.0.1/mappostgis.c
> My one is dated 14 oct 2003, so the bug is more recent.
Try using the latest mappostgis.c from CVS.
dave
