[postgis-users] simplify() on lat/lon data
Tyler Mitchell TMitchell at lignum.com
Fri May 21 09:58:00 PDT 2004
> Theres distance-on-ellipse calculations already available in postgis -
> see postgis_proj.c.
> You can call distance_ellipse() to give the distance-on-ellipse or you
Do you mean distance_ellipsoid which is available in pg through
distance_spheroid?
> can call distance_sphere_method() which is much faster but less
> accurate.  For distances in the "few meters" range, I recommend the
> distance_sphere_method() - see the documentation for how it works.
What's a valid value for "spheroid"?
> REMEMBER: the lat/lot number have to be in radians (i.e. *M_PI/180.0).
*M_PI ?
