[postgis-users] Compilation
Paul Ramsey
pramsey at refractions.net
Fri May 28 10:49:04 PDT 2004
If you want an RPM, why not use the SRPMS provided at
http://postgis.refractions.net/rpms ? And no, there is not a document
because it is not an 1,2,3 kind of thing. You learn enough about
compilation and RPM, and then you just do it. I started with the
postgresql source RPM and worked from there to create a unified SRPM
including postgis.
Rider Matey wrote:
> Hi
> Similar to what the other person had with his
> compilation problem, I tried to go through the
> instructions. The problem I had was if I download the
> source from postgres then how do I put postgis into
> the redhat postgres installation?. Is there a document
> on how to create redhat postgresql rpms which include
> postgis
> Thanks in advance.
> Roger
> Shaz,
> I run a redhat 7.3 installation, and it requires a
> postgresql source
> tree,
> and a few other gizmos. Details are available:
> http://postgis.refractions.net/docs/c59.html
> Good luck, and if you run into problems, email, I may
> have some
> assistance.
> r..b.
> At 10:48 AM 5/28/2004 +0100, you wrote:
>>Hi
>>I am new to postgis. I want to compile postgis with
>>redhat postgres 7.3. Could anyone please explain how
>>this is done for redhat versions. I know you have
> rpms
>>but I would like to try to compile it myself. Any
> help
>>will be very much appreciated.
>>Thanks
>>Shaz
> ____________________________________________________________
> Yahoo! Messenger - Communicate instantly..."Ping"
> your friends today! Download Messenger Now
> http://uk.messenger.yahoo.com/download/index.html
> postgis-users mailing list
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
