[postgis-users] using postgis cvs: how to update db?
Vincent Schut schut at sarvision.com
Mon Nov 1 01:02:17 PST 2004
If I use (and regularly update and install) postgis from cvs, how should
I keep my db up to date with the most recent postgis functionality?
re-issuing the (lw)postgis.sql results in errors because histogram2d
already exists. Should I use create_undef.pl? If yes, what is exactly
the command flow to update postgis and the db?
Thanks,
Vincent.
