[postgis-users] transform error for swiss projection
Johannes Bühler johannesbuehler at oderbruecke.de
Mon Nov 1 07:36:00 PST 2004
im trying to transform a geometry from wgs84 to the swiss epsg:2056 or epsg:21781. i compiled postgis 0.9 with postgresql 8.0beta4 and have the most current version of proj4 (4.4.9) installed as well. but when i execute the folling statement
select transform(GeometryFromText('POINT(7.675133 47.533609)',4326), 21781);
i get the following error message.
FEHLER:  tranform: couldnt parse proj4 output string
KONTEXT:  PL/pgSQL function "transform" line 2 at return
using other target projections it works.
using the most current gdal 1.2.3 the conversation is fine. But there has been the same problem before as described in
http://bugzilla.remotesensing.org/show_bug.cgi?id=423
so probably its the same problem
Thanks for any help
with kind regards
Johannes Buehler
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20041101/0769619d/attachment.pgp>
