[postgis-users] transform error for swiss projection
Johannes Bühler
johannesbuehler at oderbruecke.de
Mon Nov 1 08:58:26 PST 2004
Hi frank,
thanks for your quick answer. unfortunately i cannot load your sql insert. :( but i will try do to an update command.
the log is attached.
Johannes
On Mon, 1 Nov 2004 17:25:41 +0100
strk at refractions.net wrote:
> > >>http://home.gdal.org/~warmerdam/srs.sql
> > >ERROR 404: Not Found.
> > Sorry...
> > http://home.gdal.org/~warmerda/srs.sql
> > Best regards,
> No problem. Thank you.
> I think we already had this discussion, but again:
> can the spatial_ref_sys you provide safely replace the older one
> still being able to work with older proj releases ?
> --strk;
> > I set the clouds in motion - turn up | Frank Warmerdam,
> > warmerdam at pobox.com
> > light and sound - activate the windows | http://pobox.com/~warmerdam
> > and watch the world go round - Rush | Geospatial Programmer for Rent
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20041101/07c91aec/attachment.obj>
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20041101/07c91aec/attachment.pgp>
