[postgis-users] transform error for swiss projection
Frank Warmerdam
warmerdam at pobox.com
Mon Nov 1 09:23:44 PST 2004
Johannes Bühler wrote:
> Hi frank,
> thanks for your quick answer. unfortunately i cannot load your sql insert. :( but i will try do to an update command.
> the log is attached.
Johannes,
OK, I found a couple issues.
First, I need to run with the -skip parameter to skip over failed translations.
Some EPSG coordinate systems have no PROJ.4 analog that I am aware of.
Second, at least one entry includes a single quote in the WKT and this needs
to be SQL escaped (doubled). I have added support in GDAL CVS's epsg_tr.py
for this. The file has been newly generated using:
epsg_tr.py -skip -postgis -list ~/gdal/data/pcs.csv > ~/public_html/srs.sql
epsg_tr.py -skip -postgis -list ~/gdal/data/gcs.csv >> ~/public_html/srs.sql
I have successfully run this through psql to load and it seems to work.
The file is one against at:
http://home.gdal.org/~warmerda/srs.sql
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
