[postgis-users] ArcGIS Data Interoperability Extension
Guy Carpenter guyc at atgis.com.au
Mon Nov 1 15:21:37 PST 2004
I'm truly mistified (and deeply envious!)
that PgArc works for you with ArcGIS 9.0.
I tried all of the versions I could lay my
hands on - they all appear to be essentially
the same - built with a dependency on the ArcGIS 8.3
library structure.
Here's the essence of the problem that I am seeing:
http://arcgisdeveloperonline.esri.com/ArcGISDeveloper/ArcGISDevHelp/Technica
lDocuments/Migrating/Migratingfrom83to90.htm
	At ArcGIS 9.0 there has been a change to a more modular arrangement
	of ArcObjects, meaning that there are many different type libraries
to
	contain all of the ArcObjects type information - effectively
esriCore.olb
	has been split up into smaller, more manageable and modular
libraries.
	The libraries are grouped mainly according to functionality, for
example:
	Geometry, Cartography, Geodatabase etc.
Paolo, could I impose on you to send me the PgArc package you
are using so I can test with your version?  If you
could send it to <guyc at atgis dot com dot au> I'd be most
grateful.
Cheers,
Guy.
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of Paolo
PP. Pulli
Sent: Friday, 29 October 2004 8:27 PM
To: PostGIS Users Discussion
Subject: R: [postgis-users] ArcGIS Data Interoperability Extension
Howdy,
On my system pgArc work fine.
W2k sp4
ArcGis9 Licence type: ArcView (Build 538)
PgArc (I don't use CVS version)
PostGis for Win (http://dl.maptools.org/dl/ms4w/pgsql75win_ms4w.zip)
[ E:\SW_inst\PostGIS\ms4w\apps\pgsql75win\bin>psql -V
  psql (PostgreSQL) 7.5devel
  contains support for command-line editing           ]
ODBC Postgis 7.03.01.00
In next msg I've attached some srceenshot
This extension has some problem (you can see a frequent error message).
Tips:
When you do a change on your feature save it before stop session edit.
Only then you can (Export/)Update in PostGis.
WishList:
1) Test on large amount of data (assurance No error msg)
2) On Stop Editing automatic launch Update Postgis Table (in
background).
3) Any thing else?!
Paolo
ICQ: 254248123
MOBILE: + 39 339 3one two7 822
> That's as far as I've gotten so far - I'm still get enough context to
figure out what's going on here.
> A previous post indicated that PgArc *did* work with
> ArcGIS 9.0.  I wonder how?
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
Type: application/ms-tnef
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20041102/a8c73265/attachment.bin>
