[postgis-users] Same tablename, different schema problems
Don Drake
don at drakeconsult.com
Tue Nov 16 14:11:28 PST 2004
OK, I'm at a good spot to upgrade to 0.9 since I need to reload all of our
data before we add another 10 million rows (points).
I hope the upgrades get easier since my DB is only getting bigger.
Thanks.
-Don
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
strk at refractions.net
Sent: Tuesday, November 16, 2004 11:43 AM
To: Don Drake; PostGIS Users Discussion
Subject: Re: [postgis-users] Same tablename, different schema problems
On Tue, Nov 16, 2004 at 11:13:01AM -0600, Don Drake wrote:
> In my development database, running PostGIS version (0.8 USE_GEOS=1
> USE_PROJ=1 USE_STATS=1) I created a new schema to test some table
> partitioning.
> I created a copy of a table in another schema with the same table
> name. I was able to create the table, run addGeometry passing in the
> schema name, etc. All was good until I ran update_geometry_stats().
> I now get the following error message:
> ERROR: more than one row returned by a subquery used as an expression
> If I rename the table in the test schema, the error message goes away.
> Is this a known problem?
> Thanks.
> -Don
Don, I think the patch was included in postgis-0.9.
What you can try is download the package, configure and build.
Then take from postgis.sql just the functions you need:
find_extent(varchar, varchar, varchar);
build_histogram2d(histogram, schema, table, column);
update_geometry_stats();
Hopefully this kind of upgrades (scripts only) will be easier
in the future.
--strk;
> Donald Drake
> President
> Drake Consulting
> http://www.drakeconsult.com/
> 312-560-1574
> postgis-users mailing list
