[postgis-users] Spatial Query Benchmarks?
Paul Ramsey pramsey at refractions.net
Fri Nov 19 10:19:09 PST 2004
As Craig says, you have to create a tool that simulates your expected
load.  JMeter supports extensions, you could write a JDBC based
extension that varies the things you expect will be varied (bbox,
complexity, etc) in the patterns you expect. Then JMeter can handle the
complexity of setting up a multithreaded load and gathering stats. We
used this approach for some mapserver benchmarking.
P
Craig Miller wrote:
> I was only offering the Web App up as an example.  The same approach applies
> regardless of the type of application.
> - Identify a reasonable set of use-case based scenarios.
> - Create a multi-threaded (or multiple single threaded) application that can
> execute these scenarios in parallel. Preferably one that is controlled via a
> config file.
> - Play with the numbers in the config file.  E.g. number of simultaneous
> users, size of AOIs, etc.
> - Log the time to fulfill each request with 10, 20, 50, 100, 200, 500, 1000
> simultaneous users.
> - Log any requests that time-out
> - Log any requests that are answered incorrectly.
> - Mine the data
> The program could be as simple as a shell script executing psql.  If there
> is a client application, then it is best to write the tests on top of at
> least the data access objects portion of the application.  The higher up in
> the application you can hook your tests in the better.
> How are your users accessing the database?  Psql, c app on libpq, java app
> on top of geotools?
> --Craig
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Ethan
> Alpert
> Sent: Friday, November 19, 2004 9:59 AM
> To: PostGIS Users Discussion
> Subject: RE: [postgis-users] Spatial Query Benchmarks?
> Well it's not a web app. The problem is it provides users a method of
> managing AOI's and querying a fairly large spatial database at user
> defined intervals for new intersects of their AOI's. The reason this is
> a problem is although the geometry in the database is well defined the
> user's AOI's vary in size, vertice count and ring count. So I need to
> know at what point will the number of user AOI's affect QoS.
> -e
> Craig Miller
> Sent: Friday, November 19, 2004 10:53 AM
> To: 'PostGIS Users Discussion'
> If you have written an application on top of PostGIS, then the best way
> to profile it is to profile the entire solution.  E.g. if it is a web
> application then throw WebLoad at it.  By using something like WebLoad,
> you can mimic typical use-cases, and then have n number of users
> simultaneously hitting it using these typical use-cases.  This will test
> the real-world load rather than the theoretical maximums.
> --Craig
> Ethan Alpert
> Sent: Friday, November 19, 2004 9:36 AM
> Subject: [postgis-users] Spatial Query Benchmarks?
> Anyone have any suggestions for benchmarking? I've got some services
> I've built and my management's not going to let me deploy until I can
> quantify at what point my it will break on the current architecture.
> Anyone thought about how to determine this kind of information?
> How can I know, even heuristically, how many queries/sec my machine can
> sustain, given the tuple and/or vertice count in a given table?
> Are tuple and vertice count the only things I should be concerned about
> or should I also try to thing about geometry shape (convex,concave,
> multiple rings,etc) wrt performance.
> -e
> postgis-users mailing list postgis-users at postgis.refractions.net
