[postgis-users] upgrading to 0.9
strk at refractions.net
Wed Nov 24 02:33:36 PST 2004
On Wed, Nov 24, 2004 at 12:46:16AM -0500, Joel Gwynn wrote:
> Again I come humbly to the group. I'm upgrading from 0.8 to 0.9, and
> trying to run postgis.sql. First I got the error,
> psql:postgis.sql:42: ERROR: stat failed on file
> '$libdir/libpostgis.so.0.9': No such file or directory block
> so I edited postgis.sql and replaced $libdir with the path to my
> libpostgis.so.0.9: /usr/local/pgsql/lib/
I really don't like this. Don't you have /usr/local/pgsql/lib/postgres
directory ? What does pg_config --pkglibdir tells you ?
> Now I get this error:
> psql:postgis.sql:42: ERROR: Load of file
> /usr/local/pgsql/lib/libpostgis.so.0.9 failed:
> /usr/local/pgsql/lib/libpostgis.so.0.9: undefined symbol: PG_NARGS
> and I have no place to go.
> This is on Debian linux, postgres 7.2.1
> TIA
> Joel
In postgis.h add the following lines:
#ifndef PG_NARGS
#define PG_NARGS() (fcinfo->nargs)
#endif // ndef PG_NARGS
--strk;
> postgis-users mailing list
