[postgis-users] upgrading to 0.9
Joel Gwynn
joelman at gmail.com
Wed Nov 24 14:19:40 PST 2004
On Wed, 24 Nov 2004 11:33:36 +0100, strk at refractions.net
<strk at refractions.net> wrote:
> On Wed, Nov 24, 2004 at 12:46:16AM -0500, Joel Gwynn wrote:
> > Again I come humbly to the group. I'm upgrading from 0.8 to 0.9, and
> > trying to run postgis.sql. First I got the error,
> > psql:postgis.sql:42: ERROR: stat failed on file
> > '$libdir/libpostgis.so.0.9': No such file or directory block
> > so I edited postgis.sql and replaced $libdir with the path to my
> > libpostgis.so.0.9: /usr/local/pgsql/lib/
> I really don't like this. Don't you have /usr/local/pgsql/lib/postgres
> directory ? What does pg_config --pkglibdir tells you ?
> > Now I get this error:
> > psql:postgis.sql:42: ERROR: Load of file
> > /usr/local/pgsql/lib/libpostgis.so.0.9 failed:
> > /usr/local/pgsql/lib/libpostgis.so.0.9: undefined symbol: PG_NARGS
> > and I have no place to go.
> > This is on Debian linux, postgres 7.2.1
> > TIA
> > Joel
> In postgis.h add the following lines:
> #ifndef PG_NARGS
> #define PG_NARGS() (fcinfo->nargs)
> #endif // ndef PG_NARGS
> --strk;
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
Looks like my installation is confused. It's installing to
/usr/local/pgsql/, but pg_config is pointing to /usr/lib/postgresql/.
I think what happened is that I installed postgres using apt-get, but
since I needed the source to install postgis, I installed the source,
but configured it incorrectly.
Do I need to start over?
