[postgis-users] library loading error
collin collin at socrates.berkeley.edu
Tue Nov 30 07:56:00 PST 2004
Greetings,
I have compiled postgresql 8.0beta5, geos2.0.1, proj 4.4.9, and postgis
form cvs (11/26) successfully on Fedora Core 3.
I have loaded a number or datasets into the database (sample lidar
points) and run gist, viewed with jump, etc without a problem.
After a round of Up2Date updates however, this morning I have received
the following error:
ERROR:  could not load library "/usr/local/pgsql/lib/liblwgeom.so.1.0":
libgeos.so.2: cannot open shared object file: No such file or directory
This occurs any time I try to select or operate on any table with
geometry.
I tried ldconfig /usr/local/pgsql/lib/, and i have $LD_LIBRARY_PATH =
/usr/local/pgsql/lib/ in my master startup profile.  Despite this, it
still throws the error.
Any ideas?
Thanks,
Collin Bode
GIS Informatics Researcher
UC Berkeley
