[postgis-users] library loading error
strk at refractions.net
Tue Nov 30 08:00:11 PST 2004
run ldconfig after GEOS install ?
--strk;
On Tue, Nov 30, 2004 at 07:56:00AM -0800, collin wrote:
> Greetings,
> I have compiled postgresql 8.0beta5, geos2.0.1, proj 4.4.9, and postgis
> form cvs (11/26) successfully on Fedora Core 3.
> I have loaded a number or datasets into the database (sample lidar
> points) and run gist, viewed with jump, etc without a problem.
> After a round of Up2Date updates however, this morning I have received
> the following error:
> ERROR: could not load library "/usr/local/pgsql/lib/liblwgeom.so.1.0":
> libgeos.so.2: cannot open shared object file: No such file or directory
> This occurs any time I try to select or operate on any table with
> geometry.
> I tried ldconfig /usr/local/pgsql/lib/, and i have $LD_LIBRARY_PATH =
> /usr/local/pgsql/lib/ in my master startup profile. Despite this, it
> still throws the error.
> Any ideas?
> Thanks,
> Collin Bode
> GIS Informatics Researcher
> UC Berkeley
> postgis-users mailing list
