[postgis-users] library loading error
collin collin at socrates.berkeley.edu
Tue Nov 30 08:51:20 PST 2004
No, I ran it after geos,proj4,postgresql install, but before postgis
install.  Then I ran it again after postgis install.
Should I have run it immediately after geos install?
Collin
strk at refractions.net wrote:
> run ldconfig after GEOS install ?
> --strk;
> On Tue, Nov 30, 2004 at 07:56:00AM -0800, collin wrote:
>>Greetings,
>>I have compiled postgresql 8.0beta5, geos2.0.1, proj 4.4.9, and postgis
>>form cvs (11/26) successfully on Fedora Core 3.
>>I have loaded a number or datasets into the database (sample lidar
>>points) and run gist, viewed with jump, etc without a problem.
>>After a round of Up2Date updates however, this morning I have received
>>the following error:
>>ERROR:  could not load library "/usr/local/pgsql/lib/liblwgeom.so.1.0":
>>libgeos.so.2: cannot open shared object file: No such file or directory
>>This occurs any time I try to select or operate on any table with
>>geometry.
>>I tried ldconfig /usr/local/pgsql/lib/, and i have $LD_LIBRARY_PATH =
>>/usr/local/pgsql/lib/ in my master startup profile.  Despite this, it
>>still throws the error.
>>Any ideas?
>>Thanks,
>>Collin Bode
>>GIS Informatics Researcher
>>UC Berkeley
>>_______________________________________________
>>postgis-users mailing list
>>postgis-users at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
