[postgis-users] library loading error
strk at refractions.net
Tue Nov 30 08:59:13 PST 2004
On Tue, Nov 30, 2004 at 08:51:20AM -0800, collin wrote:
> No, I ran it after geos,proj4,postgresql install, but before postgis
> install. Then I ran it again after postgis install.
> Should I have run it immediately after geos install?
No. But you did have to run it.
ldconfig -v
gives you a list of 'found' libraries (under Linux)
--strk;
> Collin
> strk at refractions.net wrote:
> >run ldconfig after GEOS install ?
> >--strk;
> >On Tue, Nov 30, 2004 at 07:56:00AM -0800, collin wrote:
> >>Greetings,
> >>I have compiled postgresql 8.0beta5, geos2.0.1, proj 4.4.9, and postgis
> >>form cvs (11/26) successfully on Fedora Core 3.
> >>I have loaded a number or datasets into the database (sample lidar
> >>points) and run gist, viewed with jump, etc without a problem.
> >>After a round of Up2Date updates however, this morning I have received
> >>the following error:
> >>ERROR: could not load library "/usr/local/pgsql/lib/liblwgeom.so.1.0":
> >>libgeos.so.2: cannot open shared object file: No such file or directory
> >>This occurs any time I try to select or operate on any table with
> >>geometry.
> >>I tried ldconfig /usr/local/pgsql/lib/, and i have $LD_LIBRARY_PATH =
> >>/usr/local/pgsql/lib/ in my master startup profile. Despite this, it
> >>still throws the error.
> >>Any ideas?
> >>Thanks,
> >>Collin Bode
> >>GIS Informatics Researcher
> >>UC Berkeley
> >>_______________________________________________
> >>postgis-users mailing list
> >>postgis-users at postgis.refractions.net
> >>http://postgis.refractions.net/mailman/listinfo/postgis-users
