[postgis-users] library loading error
collin
collin at socrates.berkeley.edu
Tue Nov 30 10:25:46 PST 2004
I ran ldconfig -v. liblwgeom.so.1.0 was found, but libgeos.so.2.0.1 was
not. I guess I may not have run it after all for /usr/local/lib. So I
ran it with /usr/local/lib.
After adding local/lib and rebooting, postgresql is now recognizing
geometries properly. Thanks!
Collin
strk at refractions.net wrote:
> On Tue, Nov 30, 2004 at 08:51:20AM -0800, collin wrote:
>>No, I ran it after geos,proj4,postgresql install, but before postgis
>>install. Then I ran it again after postgis install.
>>Should I have run it immediately after geos install?
> No. But you did have to run it.
> ldconfig -v
> gives you a list of 'found' libraries (under Linux)
> --strk;
>>Collin
>>>run ldconfig after GEOS install ?
>>>--strk;
>>>On Tue, Nov 30, 2004 at 07:56:00AM -0800, collin wrote:
>>>>Greetings,
>>>>I have compiled postgresql 8.0beta5, geos2.0.1, proj 4.4.9, and postgis
>>>>form cvs (11/26) successfully on Fedora Core 3.
>>>>I have loaded a number or datasets into the database (sample lidar
>>>>points) and run gist, viewed with jump, etc without a problem.
>>>>After a round of Up2Date updates however, this morning I have received
>>>>the following error:
>>>>ERROR: could not load library "/usr/local/pgsql/lib/liblwgeom.so.1.0":
>>>>libgeos.so.2: cannot open shared object file: No such file or directory
>>>>This occurs any time I try to select or operate on any table with
>>>>geometry.
>>>>I tried ldconfig /usr/local/pgsql/lib/, and i have $LD_LIBRARY_PATH =
>>>>/usr/local/pgsql/lib/ in my master startup profile. Despite this, it
>>>>still throws the error.
>>>>Any ideas?
>>>>Thanks,
>>>>Collin Bode
>>>>GIS Informatics Researcher
>>>>UC Berkeley
>>>>_______________________________________________
>>>>postgis-users mailing list
>>>>postgis-users at postgis.refractions.net
>>>>http://postgis.refractions.net/mailman/listinfo/postgis-users
