[postgis-users] transform to postgis
Ethan Alpert ealpert at digitalglobe.com
Mon Oct 4 14:22:37 PDT 2004
Ugh...don't know why that got formatted so bad.  This should look
better:
Something like:
use DBI;
$dbh =
DBI->connect("DBI:Pg:dbname=<dbname>;host=<host>","<user>","<pwd>")
                        or die "Could not connect to db\n";
$dbh->do("create table mytable (station int, the_geom geometry)");
$dbh->do("CREATE INDEX mytable_oid ON mytable (oid)");
$dbh->do("CREATE INDEX mytable_spatial ON mytable USING GIST ( the_geom
GIST_GEOMETRY_OPS)";
while(<>) {
	chomp;
	($id,$east,$north) = split /\s+/;
	$dbh->do("insert into mytable (station,the_geom) value
($id,GeometryFromText('POINT($east $north)',<srid>))");
%> cat your.dat | ./thisperl.pl
