[postgis-users] transform to postgis
Paul Ramsey
pramsey at refractions.net
Mon Oct 4 14:33:21 PDT 2004
BTW: it is always better practice to create your indexes *after* your
bulk load, otherwise you end up doing an index update for every insert
(expensive!)
Ethan Alpert wrote:
> Ugh...don't know why that got formatted so bad. This should look
> better:
> Something like:
> use DBI;
> $dbh =
> DBI->connect("DBI:Pg:dbname=<dbname>;host=<host>","<user>","<pwd>")
> or die "Could not connect to db\n";
> $dbh->do("create table mytable (station int, the_geom geometry)");
> $dbh->do("CREATE INDEX mytable_oid ON mytable (oid)");
> $dbh->do("CREATE INDEX mytable_spatial ON mytable USING GIST ( the_geom
> GIST_GEOMETRY_OPS)";
> while(<>) {
> chomp;
> ($id,$east,$north) = split /\s+/;
> $dbh->do("insert into mytable (station,the_geom) value
> ($id,GeometryFromText('POINT($east $north)',<srid>))");
> %> cat your.dat | ./thisperl.pl
> postgis-users mailing list
