[postgis-users] transform to postgis
Paul Ramsey
pramsey at refractions.net
Mon Oct 4 15:13:55 PDT 2004
One other thing, due to the "power of the pipe" you don't need to use
DBI/DBD to do data loading (I never do).
-- command
perl myscript.pl myfile.txt | psql mydatabase
-- myscript.pl
print qq{
CREATE TABLE mytable (
station INTEGER,
the_geom GEOMETRY
BEGIN;
while(<>) {
chomp;
($id,$east,$north) = split /\s+/;
print qq{
INSERT INTO mytable VALUES (
$id,
GeometryFromText('POINT($east $north)',<srid>)
print qq{
CREATE INDEX mytable_oid ON mytable (oid)
CREATE INDEX mytable_spatial
ON mytable
USING GIST ( the_geom );
END;
Paul Ramsey wrote:
> BTW: it is always better practice to create your indexes *after* your
> bulk load, otherwise you end up doing an index update for every insert
> (expensive!)
> Ethan Alpert wrote:
>> Ugh...don't know why that got formatted so bad. This should look
>> better:
>> Something like:
>> use DBI;
>> $dbh =
>> DBI->connect("DBI:Pg:dbname=<dbname>;host=<host>","<user>","<pwd>")
>> or die "Could not connect to db\n";
>> $dbh->do("create table mytable (station int, the_geom geometry)");
>> $dbh->do("CREATE INDEX mytable_oid ON mytable (oid)");
>> $dbh->do("CREATE INDEX mytable_spatial ON mytable USING GIST ( the_geom
>> GIST_GEOMETRY_OPS)";
>> while(<>) {
>> chomp;
>> $dbh->do("insert into mytable (station,the_geom) value
>> ($id,GeometryFromText('POINT($east $north)',<srid>))");
>> %> cat your.dat | ./thisperl.pl
