[postgis-users] Backend crashes when collect()ing Box3ds
strk at refractions.net
Wed Oct 6 00:31:35 PDT 2004
Ron, 0.8 is not maintaned anymore.
Should try 0.9.0 or pgis_0_9_0 CVS branch.
The && problem is not a bug, it's a 2d-only operation.
The intersets() seems a bug, what GEOS version are you using ?
(GEOS-2.0.1 is out).
For the collect() case I bet it's an OutOfMemory condition, often
overlooked. Postgis-1.0 will have a memory management layer, that
would help in this cases.
The ordering operator is a missing btree operator class needed
for postgresql >= 74. Can't remember which postgis version introduced
it for geometry, BOX3D=>GEOMETRY cast is implicit so that should do.
--strk;
On Tue, Oct 05, 2004 at 10:55:23PM -0700, Ron Mayer wrote:
> If this mailinglist isn't the right place for such postings, let me know
> and I'll go elsewhere.
> If I memcollect() or collect() BOX3Ds, sometimes I get a reasonable error
> message, but sometimes I get a crashed backend. I know I shouldn't be
> doing this (collect()ing the envelope() is what I really wanted), but a
> crashed backend wasn't what I expected either, so I thought I'd mention
> it.
> On SuSE 9, Postgresql 7.4.3, Postgis 0.8
> I get the "server closed the connection unexpectedly", and
> On Windows 2000, Postgresql 8.0.0.beta2, Postgis 0.8.2
> I get a hung psql client and apparently the backend vanished
> but I get no error message.
> The easiest testcase I can come up with that shows the crash is
> select state,memcollect(bb) from (
> select state,box3d(the_geom)::box3d as bb
> from statesp020
> where state='California'
> ) as a group by state;
> with the statesp020 table coming from this shapefile:
> http://edcftp.cr.usgs.gov/pub/data/nationalatlas/statesp020.tar.gz
> Below are the results of a few such memcollect()s and
> fl=# select memcollect(bb) from (select 'BOX3D(0 0, 1 1)'::box3d as bb) as a;
> memcollect
> SRID=-1;BOX3D(0 0 0,1 1 0)
> (1 row)
> fl=# select memcollect(bb) from (select 'BOX3D(0 0, 1 1)'::box3d as bb union select 'BOX3D(1 0, 1 1)'::box3d as bb) as a;
> ERROR: could not identify an ordering operator for type box3d
> HINT: Use an explicit ordering operator or modify the query.
> fl=# select state,memcollect(bb) from (select state,box3d(the_geom)::box3d as bb from statesp020 where state='California') as a group by state;
> This probably means the server terminated abnormally
> before or while processing the request.
> The connection to the server was lost. Attempting reset: Failed.
> > ########## more version info ###########
> > fl=# -- [on the windows machine]
> > fl=# select name,setting,postgis_full_version() from pg_settings where name = 'server_version';
> > name | setting | postgis_full_version
> > server_version | 8.0.0beta2 | POSTGIS="0.8.2" GEOS="2.0.0" PROJ="Rel. 4.4.8, 3 May 2004" USE_STATS DBPROC="0.0.1" RELPROC="0.0.1"
> > (1 row)
> > fl=# -- [on the SuSE machine (postgis_full_version doesn't exist)]
> > fl=# select name,setting,postgis_version() from pg_settings where name = 'server_version';
> > name | setting | postgis_version
> > server_version | 7.4.3 | 0.8 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
> postgis-users mailing list
