[postgis-users] Backend crashes when collect()ing Box3ds
Ron Mayer
rm_postgis at cheapcomplexdevices.com
Wed Oct 6 03:37:28 PDT 2004
On Wed, 6 Oct 2004 strk at refractions.net wrote:
> mmm.. check how those BOX3d gets casted to a geometry.
> The problem might be in the cast only using 2d.
Seems so...
fl=# select envelope('BOX3D(-1 -1 -1, 1 1 -2)'),
envelope('BOX3D(-1 -1 1, 1 1 2)');
envelope | envelope
SRID=-1;POLYGON((-1 -1,-1 1,1 1,1 -1,-1 -1)) | SRID=-1;POLYGON((-1 -1,-1 1,1 1,1 -1,-1 -1))
I'll check with the latest versions and if it's still happening I'll
mention it (on the geos list?).
but I'll hold off testing any more until I get the latest version
> > > Should try 0.9.0 or pgis_0_9_0 CVS branch.
> > On the windows machine I used the pre-compiled binary form dcmms
> > that was called "postgis-setup-0.9.0-1.exe" yet
> > postgis_full_version() tells me it's "POSTGIS="0.8.2". Hmm.
> > Guess I'll need to learning how to compile something with windows.
> > If I figure out how to use a complie on wndows, I'll try GEOS2.0.1
> > there as well.
> That's very bad :(
> Try also postgis_lib_version() but that should ont change.
> Are you sure the library you're using (check probin from pg_proc
> where proname = 'postgis_lib_version') is the 0.9.0 one ?
All it really says is '$libdir/libpostgis.dll', and when I do a strings of
it I see 0.8.2 and no 0.9.0. However the only installer .exe currently
on the machine (according to find files) is called postgis-setup-0.9.0-1.exe.
I'll ask around work tomorrow (ugh, later today) to see if anyone else
might have touched it.
Thanks for your pointers so far. I'll re-do the whole experiment being
carful to note the things you mentioned before taking more of your time.
Ron
