[postgis-users] Backend crashes when collect()ing Box3ds
strk at refractions.net strk at refractions.net
Wed Oct 6 03:43:46 PDT 2004
On Wed, Oct 06, 2004 at 03:37:28AM -0700, Ron Mayer wrote:
> On Wed, 6 Oct 2004 strk at refractions.net wrote:
> > mmm.. check how those BOX3d gets casted to a geometry.
> > The problem might be in the cast only using 2d.
> Seems so...
> fl=# select envelope('BOX3D(-1 -1 -1, 1 1 -2)'),
>             envelope('BOX3D(-1 -1  1, 1 1  2)');
>                    envelope                   |                   envelope
>  SRID=-1;POLYGON((-1 -1,-1 1,1 1,1 -1,-1 -1)) | SRID=-1;POLYGON((-1 -1,-1 1,1 1,1 -1,-1 -1))
> I'll check with the latest versions and if it's still happening I'll
> mention it (on the geos list?).
Don't bother... the envelope(geometry) thing is in my todo list,
not implemented yet.
Probably will never get into the 0_9_0 branch...
(unless you make enough noise).
(cuts)
> > > On the windows machine I used the pre-compiled binary form dcmms
> > > that was called "postgis-setup-0.9.0-1.exe" yet
> > > postgis_full_version() tells me it's "POSTGIS="0.8.2".   Hmm.
> > > Guess I'll need to learning how to compile something with windows.
> > > If I figure out how to use a complie on wndows, I'll try GEOS2.0.1
> > > there as well.
> > That's very bad :(
> > Try also postgis_lib_version() but that should ont change.
> > Are you sure the library you're using (check probin from pg_proc
> > where proname = 'postgis_lib_version') is the 0.9.0 one ?
> All it really says is '$libdir/libpostgis.dll', and when I do a strings of
> it I see 0.8.2 and no 0.9.0.   However the only installer .exe currently
> on the machine (according to find files) is called postgis-setup-0.9.0-1.exe.
> I'll ask around work tomorrow (ugh, later today) to see if anyone else
> might have touched it.
> Thanks for your pointers so far.  I'll re-do the whole experiment being
> carful to note the things you mentioned before taking more of your time.
Thank you.
I don't think this is a waste of time.
It makes readers (and writers) in sync..
--strk;
>    Ron
> postgis-users mailing list
