[postgis-users] Import from SDE(oracle)
Joshua Lieberman
josh at oklieb.net
Tue Oct 12 11:13:23 PDT 2004
Also possible to use SDE (sde2shp) and PostGIS(psglshp utilities to
transfer via shapefile.
--josh(those_with_too_much_money_should_use_oracle);
On Oct 12, 2004, at 11:34 AM, strk at refractions.net wrote:
> On Tue, Oct 12, 2004 at 10:17:36AM -0500, David Bitner wrote:
>> What options exist for migrating data from SDE(Oracle) to PostGIS?
>> Right now, the only one I know of is the Safe Software FME.
>> Are there any free/open alternatives?
> Doesn't SDE export in WKT/WKB ?
> --strk(nobody_should_use_oracle);
>> Thanks,
>> David
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Joshua Lieberman, Ph.D.
geospatial architect
josh at oklieb.net
tel (857) 919-1071
fax (775) 514-6621
