[postgis-users] Import from SDE(oracle)
Joshua Lieberman josh at oklieb.net
Tue Oct 12 11:34:55 PDT 2004
(pgsql2shp)...
On Oct 12, 2004, at 2:13 PM, Joshua Lieberman wrote:
> Also possible to use SDE (sde2shp) and PostGIS(psglshp utilities to
> transfer via shapefile.
> --josh(those_with_too_much_money_should_use_oracle);
> On Oct 12, 2004, at 11:34 AM, strk at refractions.net wrote:
>> On Tue, Oct 12, 2004 at 10:17:36AM -0500, David Bitner wrote:
>>> What options exist for migrating data from SDE(Oracle) to PostGIS?
>>> Right now, the only one I know of is the Safe Software FME.
>>> Are there any free/open alternatives?
>> Doesn't SDE export in WKT/WKB ?
>> --strk(nobody_should_use_oracle);
>>> Thanks,
>>> David
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Joshua Lieberman, Ph.D.
> geospatial architect
> josh at oklieb.net
> tel (857) 919-1071
> fax (775) 514-6621
josh at oklieb.net
tel (857) 919-1071
fax (775) 514-6621
