[postgis-users] problems with postgis.sql
strk at refractions.net
Tue Oct 12 12:01:24 PDT 2004
On Tue, Oct 12, 2004 at 01:53:46PM -0500, Richard_D_Levine at raytheon.com wrote:
> Try the following:
> ldconfig /usr/local/lib
> ldconfig /usr/local/pgsql/lib
> export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/lib:/usr/local/pgsql/lib
> Hope this helps,
Won't help. The message reports as undefined a symbol that would should
be defined by libpostgis itself.
--strk;
> Rick
> | | <misalda at ixp.net> |
> | | Sent by: |
> | | postgis-users-bounces at postgis.refr|
> | | actions.net |
> | | 10/12/2004 01:44 PM |
> | | Please respond to PostGIS Users |
> | | Discussion |
> | To: <postgis-users at postgis.refractions.net> |
> | cc: |
> | Subject: [postgis-users] problems with postgis.sql |
> hello mi name is miguel and i just installed postgis under PostgreSQL 7.4.2
> on my fedora,
> the thing is that i have all the correct paths i have made all the necesary
> arragements on the make file to have my postgis work with geos. but every
> single time i try to run the postgis.sql script, to add the gis definitions
> to my database I get a lot of error messages so i decided to take part of
> the script copy it and paste directly in the command line of postgres and
> this is what i get
> CREATE OR REPLACE FUNCTION histogram2d_in(cstring)
> geoData-# RETURNS histogram2d
> geoData-# AS '/usr/local/pgsql/lib/libpostgis.so.0.9'
> geoData-# LANGUAGE 'C' WITH (isstrict);
> NOTICE: el tipo "histogram2d" no ha sido definido aún
> DETAIL: Creando una definición de tipo inconclusa.
> ERROR: no se pudo cargar la biblioteca
> "/usr/local/pgsql/lib/libpostgis.so.0.9":
> /usr/local/pgsql/lib/libpostgis.so.0.9: undefined symbol: NOTICE_MESSAGE
> The error message translated to english just say that the library
> libpostgis.so.0.9 cannot be loaded for some reason but the weird thing is
> that all the paths are correct:
> libgeos.so.0.9 is in usr/local/pgsql/lib/
> and the geos library path is set to user/lib
> im really confused in here and im running out of ideas any help would be
> greatly appreciated .
> thxs
> Miguel Andres Saldarriaga
> postgis-users mailing list
