[postgis-users] ArcGIS Data Interoperability Extension
RIBOT, Nicolas
nicolas.ribot at astrium.eads.net
Tue Oct 26 08:31:59 PDT 2004
> I'm apologize. PgArc work fine with ArcGis 9, too: read/write
> layer very
> well!
Hmm, always pleased to see that this program, developed to learn ArcObject,
is still useful for some people.
There are some improvements scheduled for the PgArc module, but developers
seem to lack time to do it, unfortunately.
(by the way, I understood that ArcGIS 9.0 was supposed to read gis data from
postgis.
Is it true ?
I never succeeded in setting a new working OleDB connection to postgis.
Nicolas.
CE COURRIER ELECTRONIQUE EST A USAGE STRICTEMENT INFORMATIF ET NE SAURAIT ENGAGER DE QUELQUE MANIERE QUE CE SOIT EADS ASTRIUM SAS, NI SES FILIALES.
SI UNE ERREUR DE TRANSMISSION OU UNE ADRESSE ERRONEE A MAL DIRIGE CE COURRIER, MERCI D'EN INFORMER L'EXPEDITEUR EN LUI FAISANT UNE REPONSE PAR COURRIER ELECTRONIQUE DES RECEPTION. SI VOUS N'ETES PAS LE DESTINATAIRE DE CE COURRIER, VOUS NE DEVEZ PAS L'UTILISER, LE CONSERVER, EN FAIRE ETAT, LE DISTRIBUER, LE COPIER, L'IMPRIMER OU EN REVELER LE CONTENU A UNE TIERCE PARTIE.
This email is for information only and will not bind EADS Astrium SAS in any contract or obligation, nor its subsidiaries.
If you have received it in error, please notify the sender by return email. If you are not the addressee of this email, you must not use, keep, disseminate, copy, print or otherwise deal with it.
