[postgis-users] Empty GeometryCollection and AsSVG
Olivier Courtin
pnine at free.fr
Wed Oct 27 04:40:22 PDT 2004
Still playing with AsSVG function, and i met a little problem, with
query like :
SELECT AsSVG(simplify(the_geom, 1000), 1, 0) FROM my_table;
With some data and with a quite high simplify tolerance parameter, the
simplify output could be empty. And become a GeometryCollection type...
And this even if the original type was a Polygon or anything else...
And as AsSVG not handle rightly GeometryCollection type, output
could be like that :
Row 1) M 572119 -1720173 l 1162 4085 -4360 -567 3198 -3518
Row 2) GEOMETRYCOLLECTION not yet supported
Row 3) M 572119 -1720173 l -3198 3518 4360 567 -1162 -4085
I provide below a partial patch for AsSvg who return an empty string if
GeometryCollection is Empty.
So result will be :
Row 2)
Any better idea ?
diff -u against current cvs head :
--- lwgeom_svg.c 2004-10-27 13:13:12.000000000 +0200
+++ patched_lwgeom_svg.c 2004-10-27 13:27:13.000000000 +0200
@@ -92,8 +92,17 @@
if (lwgeom_getType(geometry->type) == COLLECTIONTYPE)
- result = (char *)palloc(64);
- sprintf(result, "GEOMETRYCOLLECTION not yet supported");
+ inspected = lwgeom_inspect(SERIALIZED_FORM(geometry));
+ result = (char *)palloc(64);
+ if(inspected->ngeometries == 0){
+ sprintf(result, "%s", "");
+ } else {
+ sprintf(result,
+ "GEOMETRYCOLLECTION not yet supported");
return result;
HTH :)
Ol
