Fwd: [postgis-users] error loading postgis.sql on OS X 10.3.3
Benoit Ogier benoit.ogier at cbconseil.com
Mon Sep 6 03:09:22 PDT 2004
I'm new on postgis, and Mac OS X user... I found this message of
january and I got same error under OS 10.3.3 with postgres 7.4.5, GCC
3.3, and postgis 0.8.2, when using GEOS 1.0.
Did someone find any solution for this trouble ???
My config line for postgress :
LDFLAGS=-lstdc++ ./configure -bindir=/usr/local/bin
--mandir=/usr/local/share/man/ --enable-recode --with-CXX --enable-odbc
--enable-syslog --enable-unicode-conversion --enable-multibyte
Thanks,
BO
> Hi I'm back. Trying to upgrade my PostGIS installation it turned out to
> be tough to get the pieces all together, as usual!
> The error, shown below, sounds as if my Pgsql is not compiled with C++
> support, but I did indicate stdc++ on the configure options for Pgsql
> (for GEOS support) Any ideas where I went wrong?
> gcc -v
> Reading specs from /usr/libexec/gcc/darwin/ppc/3.3/specs
> Thread model: posix
> gcc version 3.3 20030304 (Apple Computer, Inc. build 1495)
> PostgreSQL 7.4.1
>         ./configure --with-perl --with-rendezvous --without-readline
> LDFLAGS="-lstdc++ -L/usr/local/lib"
> PostGIS 0.8.1
>         Makefile: USE_PROJ = 0, GEOS = 1, USE_STATS = 0
> Here is the error loading postgis.sql:
> # /usr/local/pgsql/bin/psql -U postgres -f
> /usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql -d
> aps
> BEGIN
>          message
>   PL/PgSQL is installed.
> (1 row)
> psql:/usr/local/src/postgresql-7.4.1/contrib/postgis-0.8.1/postgis.sql:
> 44: NOTICE:  type "histogram2d" is not yet defined
> DETAIL:  Creating a shell type definition.
> 44: ERROR:  could not load library
> "/usr/local/pgsql/lib/libpostgis.so.0.8": dyld:
> /usr/local/pgsql/bin/postmaster Undefined symbols:
> __ZNSs20_S_empty_rep_storageE
> __ZNSs4_Rep11_S_max_sizeE
> __ZNSs4_Rep11_S_terminalE
> __ZNSt24__default_alloc_templateILb1ELi0EE12_S_force_newE
> __ZNSt24__default_alloc_templateILb1ELi0EE12_S_free_listE
> __ZNSt24__default_alloc_templateILb1ELi0EE22_S_node_allocator_lockE
> __ZTIPv
> __ZTVN10__cxxabiv117__class_type_infoE
> __ZTVN10__cxxabiv119__pointer_type_infoE
> __ZTVN10__cxxabiv120__si_class_type_infoE
> __ZTVN10__cxxabiv121__vmi_class_type_infoE
> ___cxa_pure_virtual
> ___gxx_personality_v0
> 49: ERROR:  current transaction is aborted, commands ignored until end
> of transaction block
> ... snip rest of errors ..
> Alex Rice, Software Developer
> Architectural Research Consultants, Inc.
> <http://ARCplanning.com>
BenoƮt Ogier{
Carte Blanche Conseil
47, rue de Lancry
75010 Paris
Tel : +33 1 42 41 21 21
Fax : +33 1 42 41 70 40
email : benoit.ogier at cbconseil.com
Name: not available
Type: text/enriched
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20040906/6444676e/attachment.bin>
