[postgis-users] ESRI MapObjets
Dan Davis
DanWDavis at ij.net
Sat Sep 11 20:09:07 PDT 2004
Paul,
Thanks for the info, I will take a look at PgArc.
I am not really trying to use PostGIS as a backend to MO. I am simply trying
to capture a geographic area of interest from MO and process the query in a
separate system using PostGIS. The actual application will be for county
officials to initiate a emergency telephone notification process to a
geographic area. The idea here is to have the telephone side accept the
geographic boundary (probably WKT), query all telephone numbers that reside
in the geographic boundary and make the calls. This would keep the mapping
on the local computers for speed yet have the potentially large query and
the databases centralized on our servers.
Thanks
Dan
----- Original Message -----
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Saturday, September 11, 2004 10:18 PM
Subject: Re: [postgis-users] ESRI MapObjets
You can pass SQL through ODBC from MO to PostGIS, but you cannot
transparently use PostGIS as a spatial backend to MO (ala SDE). The
work behind PgArc resembles the kind of stuff you would have to do to
put PostGIS features on the screen in MO.
P.
On Saturday, September 11, 2004, at 07:08 PM, Dan Davis wrote:
> Does anyonw know of a way to do a postGIS query from MapObjects? I
> have a current MO project which does a ShapeSearch which I want to now
> do in PostGIS.
> Thanks
> Dan
> postgis-users mailing list
Paul Ramsey
Refractions Research
Email: pramsey at refractions.net
Phone: (250) 885-0632
