[postgis-users] postgis doc in latex
Paul Ramsey pramsey at refractions.net
Mon Sep 13 09:00:59 PDT 2004
TECHER Jean David wrote:
> Can you send me the postgis.fo ???
No way, it is a derived file, it should not be hand-edited.
> I will made the conversion too?? thanks
Yes, do the conversion. If you have fedora core 1, all the packages you
need (xmltex, passivetex, libxslt, docbook-style-xsl, docbook-dtds) are
available as standard distribution RPMs.
